Just for the low pressure oil from the crank case.Does the oil pressure gauge on the dash work for just the low pressure or high pressure?
That tells you the low pressure pump works fine, because that is what fills the reservoir.My reservoir is full of oil and it still won't start.
How old is the High Pressure Oil Pump? Rare for the new ones to quit on you.Today I'm going to pull the h-pop off and get it warrantied out with a new one.
How are you deciding which injector(s) to replace?Changed one injector and it would fire up. Next day died. Popped another one. Replaced it fired up. So I replaced the rest and it still won't start.. just here clicking. And no start.
Sounds like something clicking under the dash. Gets faster as it heats up the glow plugs.
If your Air Intake heater is shorting out, unplug it. Make sure you wrap the connector in tape because it will go hot.Lol I've read up on it and it sounds like it's a low power thing.
Best to run the FORScan on a PC.I need to order a new OBD2 Bluetooth reader. I have the FORScan app and the Fordsys app.
