1 - 20 of 20 Posts
Well im came to the conclusion that my boots need changeing my turbo ahs oil all over it and the boots show like oil is coming out of them. My question is where is the best place to buy some? any thing better then the ones from the dealer? Thanks.
I just installed a boot kit from Diesel Power Products and I am very pleased. Much more sturdy than the stockers. DieselSite's boots are oil resistant, but quite a bit more $ than the DPP ones.
owner/president
DieselSite.com:bowfast:
Custom Trailer Sales
DieselSite x2.
However, I'm surprised no ones mentioned that his boots may be fine. Clean your boots and do the CCV mod, I'd be willing to bet they're fine. Unless your sure oil is seeping out of them, or they're torn/ cracked.
Stroken it 7.3,6.0,6.4
Riffraff boots! Got them on all the trucks and they are the bomb!
Got plenty of issues
I am a RiffRaff guy also, great boots! You will find both sets (DieselSite, and RiffRaff's) are great.
DieselSite x2.
However, I'm surprised no ones mentioned that his boots may be fine. Clean your boots and do the CCV mod, I'd be willing to bet they're fine. Unless your sure oil is seeping out of them, or they're torn/ cracked.[/QUOTE
Well something is throwing oil on my hood when i pull 13,000lbs through mountains right on top of the turbo... I just cleaned all the oil so im going to see where exactly its leaking from.
I would trace that down quickly. How much oil are you loosing over how many miles?
at like 3,500-4,000 miles its at the add mark
Your got more than oil from the boots then.
Discussion Starter #15
Its not like doing tons of it but enough to see a oil stain.
Discussion Starter #16
Has anyone had this problem????
That's not all that bad.
Can you see any oil leaks or anything associated to an oil leak while the truck is idleing? Do you see any oil in your engines valley?
Fill your whole intake system with compressed air, and feel the boots for leaks, and see how long it takes to bleed off.
Discussion Starter #18
how do i put compressed air in the intake system?
I went to Home Depot and got a 4 inch flexible rubber conection and then put a 4 inch cap on the other end then added a Air press guage and an air nipple. Then you just take your air box off and conect the boost dector to it an listen.
:whs: Listen and feel for leaks, if you have a bad leak you can watch the guage move. But you don't have to put a guage on the plug weekendwarriors talking about, its a good idea though. And then save that piece for use in the future!
1 - 20 of 20 Posts
