I'm looking for step-by-step instuctions on removing and reinstalling the #8 cylinder glow-plug on a 2006 F250 SD with the 6.0L Turbo Diesel. I used an OBD-II scan tool to diagnose the check engine light as the glow plug on cylinder #8, and I have the replacement part.
I've read that this can be accomplished by disconnecting the wiring harness and using a deep well 10mm socket to gently remove the plug, however I'd like additional information on explicitly identifying the harness, plug, and connector removal as this seems to be tricky.
There seems to be an awful lot of components in the way to reach cylinder #8, can this be done without removing additional parts?
Thank-you in advance!
TopFuelWeimar
Indianapolis, IN
2006 F250 SD PowerStoke 6.0L Diesel
TopFuelWeimar
Indianapolis, IN
