1 - 2 of 2 Posts
Hey guys, i need some info. Im looking at buying a 95 7.3L with 163k on it. What are some things i should look for and ask about before buying? Are there any known issues that i should address and check before buying? What are your overall thoughts on this engine/truck? Everyone raves about the 7.3L and how bulletproof of a engine it is! Thanks in advance!
P.S. if there is any other thoughts or ideas please voice em, thanks!
Check for oil leaks around the hpop and the plugs in it, also check for fuel leaks on the fuel filter bowl and the lines around it. Check for signs of leakage on the weep hole on the water pump. Check for excessive wear on the front tires for signs of a bad alignment or ball joints.
1 - 2 of 2 Posts
