21 - 28 of 28 Posts
1997 F350 power stroke
Discussion Starter · #22 ·
Not in just one place, either. Mark the bottom with one streak, with something like a grease pencil or soap stone. Then turn it over, and see if it moves in another. Mark that place. Continue until you have tested at least four quadrants.
Ok will do. Thank you.
1997, Ford, F-250, 7.3
Worse at higher rpm and worse with right turn could be your down pipe knocking on the under side of the cab. Happened to me after installation of a 3” down pipe. Worth a look if that sounds like your situation. Fixed it with a big ol’ pry bar.
Discussion Starter · #26 ·
Oh damn I will definitely check that out first. Thanks
21 - 28 of 28 Posts
