1 - 9 of 9 Posts
Alright so my brake light in the dash is flashing on and off in no pattern and chimes while its flashing, if I turn to the right it stop. So far I have check the peddle and the fluid level which was a little low I topped it off and still the same thing. This is driving my nuts I think there is a float in the master cylinder but not sure how to get at it. Anybody have any advise or opinions?
Discussion Starter #2
Sorry my post may have been premature, I first tried unplugging the sensors on the master cylinder and the light stayed on all the time, I unplugged the sensor on the peddle and so far no light and no chime. Think I solved it for now. BTW the sensor on the peddle is a PITA!!
Thats good to know. Thanks, I would have never even thought to look, guess that means I actually have to replace the switch. Would you happen to have a part #?
TimmyaleX
check your e-brake pedal
TimmyaleX
Only a couple posts above yours. Thanks for trying to help.
TimmyaleX
1 - 9 of 9 Posts
