1 - 2 of 2 Posts
Truck is bone stock right now, doing deletes this weekend. I thought I read somewhere that your supposed to tune the truck with the custom file before you actually remove the emissions junk. I have the sct 3015R tuner and wasn't sure what to select if it asks me if I removed the egr/dpf before it loads the tune. Does gearhead put egr/dpf removal in there tunes already? I'm a previous cummins/efi live guy so I'm new to the sct 6.4 stuff. thanks
Do it all at once.
Your stock tune goes in the SCT 1st, It'll walk you through it. program vehicle and then it will ask you if you want to add custom tune. If gearhead gave you a custom tune, it'll be in there.
The SCT 3015r will ask you if you deleted the egr system, do you have a aftermarket air box and do have race exhaust while you're adding the tune.
1 - 2 of 2 Posts
