1 - 9 of 9 Posts
I need to figure out a better way to strap my front end down. The single strap over the crossmember and under the axle isnt cutting it anymore.
Anyone rigging up a better way?
I put a strap on both sides, I run it through the spring , hook on top and hook on the bottom shock mount. I use a heavy duty motorcycle strap and pull it down about 1 inch and half. Hope that helps
Dan the diesel man
We took my buddys and welded a piece of steel to the top of the axle and a bracket to the frame. Mount a shock to both of them and it works pretty nice. We had to play with what shocks to use but it pulls in the 3.0 class with no hopping
WOOOOO!!!!!
pics?
Dan the diesel man
Sorry I will get them when the truck come back my way. I should have takin them when I did it.
i need to see this because mine hops so bad with only a 100hp tune
1 - 9 of 9 Posts
