1 - 19 of 19 Posts
im trying to remove the gay ass sticker that the dealership put on the truck.
its a 1994 Toyota if that helps at all. any info would be greatly appreciated and i attached a photo. the decal is the one that's running down the side of the truck right below the windows.
wd-40 works ok. spray them down every few minutes until they start to peel or if there is a spot already peeling start there... it may take a couple cans. or tar/pine pitch remover... goo gone...
goo gone works good.. or a razor blade just under the surface of the sticker but not on the paint with some windex... then some windex on the adhesive and your good.. worked in a detail shop and that what we did to remove stickers or decals.
Don't EFN worry about it
100+ degree days here in Texas makes it easy to get stickers off. I peeled the A pillars on my 09 scion xB super easy when it was hot. If not use a hair dryer or a heat gun to make it easier.
All done now
:whs: plus one of those plastic scrapers. Then Goo Gone or WD-40 to finish up.
You can peel the sticker off and use "prepall" to remove the access gunk. Its a grease and tar remover.
ya i tried to peel it off and the stupid thing just keeps breaking. i have a big thing of goo gone so i think ill try to just keep applying it to the sticker and see where it gets me. thanks for all the info you guys are AWESOME!!!
Steamfighter
Walmart carries a 3M decal/adhesive remover .
FREE THINKER
If there is a automaotive paint store near you they sell a rubber wheel that you put on a drill and spin it slowly and it rolles the sticker right off,its what i use works awesome and intantly.;)
ive used a steamer in the past to remove tint and stickers
JDG's #1 Fan
Best way there is Hands Down. 3M makes them, they look like a big gum eraser. Took my 10 year old pin stripe right off. I got mine at a Car Quest.
TennesseeHillbilly
If it's been on there since 94 the paint undereath ain't gonna match. It might likely leave the impression of where it used to be.
1 - 19 of 19 Posts
