1 - 4 of 4 Posts
Ok I put a new ipr valve in on Thursday and new battery's had her running good. Come home plug her in and started fine. Then Friday after work so a lot of cranking to start but wasn't plug in. Then had her plug in Friday night started fine sat morning drove her 250 mile put fueled it up. Then this morning no start with no smoke out of exhaust then crank and drain battery's. So get battery charger and started right up. Let it run to check oil and shut her down and know she won't start. And I'm at a lost.
Fixing Broken Stuff
:whs: Why did you change the IRP? Check your glow plug and make sure they are all good and functioning correctly.
Renegade Diesel
kinda sounds like your batts aint charging... if they are dead everytime you try to restart and then it fired when you get a charger on it
1 - 4 of 4 Posts
