1 - 5 of 5 Posts
97 powerstroke
i want to put a d66 on my truck, but i want to make sure it will be ok runnin it with swamps 200cc/30% injectors? and wheres the best place to get a d66 and not havein to buy the whole mountin pedestel from beans and mount to stock if possible! i also i have a hypermax intercooler and want to install a 17 degree hpop
The d66 is sold by beans only, unless you buy a h2e . The d66 is a drop-in turbo,you van use the stock pedestal.
It should run fine with those injectors... And like said above, it's a direct bolt on turbo, no need for an aftermarket pedistal or anything...
Davey B
You'll really like that turbo, especially if you run Johnathan's tunes (Beans). He runs the same turbo on his own truck and is getting some really impressive #s out of it. I was actually planning on running that same charger after talking with Johnathan with my hybrids, the only reason I'm not is because I just got a really good deal on a different turbo.
1 - 5 of 5 Posts
