1 - 8 of 8 Posts
I have a 1996 Ford F-250 with the 7.3l my transmission went out and I can’t afford to rebuild the one I have right now The junkyard by me sells transmissions for pretty cheap but they rarely have 7.3‘s I have an E4 OD transmission in it now my question is what trucks could I pull a transmission out of to fit mine does it have to be out of a 7.3
Former Ford Trans Engr.
As I understand you can convert a 4r100 from a super duty 7.3 to work in your truck with relatively little work. But alas, I don’t know a ton about it.
It is possible.
You need to change the torque converter and the solenoid body. Then you need to remove the pump and change a hole in the body from 0.250" to 0.030". If you're going to do it I can look up the instructions on where this hole is located.
  • Like
Reactions: JustAFenceBuilder
1 - 8 of 8 Posts
