1 - 7 of 7 Posts
I'm trying to find rear spring mounts and shackles for the front axle on f350. I've been looking online. Found a parts truck in junk yard and found a lot of parts. But was having a little trouble with Rivits, seeing how I don't have power in a junkyard just a battery drill. Doing a 4wd conversion. Any help is appreciated.
That Is a nice alternative but it just looks like they are a huge drop bracket that's going to throw off your drive line angle... how do they compare to stock measurement?
STILL LEARNING
Cordless Sawzall? Just cut the whole chunk of the frame out and take it home
Or go to a junk yard that will burn the brackets off.
SKYs bracket is NOT for the stock setup, it is ONLY for THEIR RSK
That sounds like a good idea and I was pretty sure the Sky's kit is different dimensions and moves the mounting location forward and such. Thanks Brad
Idk why I don't think of tht I have a sawzall. Also I plan on using sky's 3" rsk does that require different spring placement than stock? What is the bar called that run behind the axle and connects to the frame?
STILL LEARNING
I would Not recommend the SKY RSK, but since you are a 2wd and need to mount the rear spring mounts anyway, you can go that route
And YES, SKYs RSK required the rear hangers to be mounted "differently" than stock. they supply you with new hangers to move the spring location hole
As for the bar behind the axle, it is a track bard or pan hard bar
1 - 7 of 7 Posts
