1 - 8 of 8 Posts
I have a 04 6.0 L need a ICP regulator (sensor) Fine thread. Everywhere I seen they had different thread.
Jackleg Mechanic
Make sure when your truck was built. One sensor is for early build trucks and late build gets a different size.
3C3Z-9F838-EA 03-04 early builds, located under turbo, check wire harnesses on both to make sure they don't need replacing at the same time.
^^ 1 1/16 socket
4C3Z-9F838-A 04-07 late builds, located on passenger valve cover
^^15/16 socket
Please verify these part numbers before purchase. Use your VIN number!
yep, sunrise or riffraff
"resident smarty pants"
The thread size on all 6.0L ICP sensors should be the same though.
Also - from what folks tell me, the newer model year ICP sensor should work just fine in the earlier model year engines. M12x1.5
Did I get the right part numbers there Mark?
And I have been seeing the newer model year able to be used in early model year.
Absolutely.
The 04 early build was up to 9/22/03.
get it from sunrise best customer service around
1 - 8 of 8 Posts
