1 - 7 of 7 Posts
PBUX690
Im lost and have been searching on here for a few hours now and can't find out what exactly is going on. I have an 06 F250 with 74k on her. Anyways this past weekend I was driving from Missouri to Kentucky and back in the matter of 24 hours. As I was driving the fan kicked on and has stayed on ever since?? Also I have no heat in the cab. It will come in and out on different occasions. The temp gauge is running normal and no puking. I dont have any gauges on the truck so I could tell you what the eot and ect are running. Any help would be greatly appreciated
Diesel Sled Head
Sounds like head gasket time. Coolant level????
PBUX690
Coolant level is fine, I was under the impression that if you had a blown head gasket the oil would be milky and there would be smoke coming out the tail pipe. None of that happens??
matt
not in every case.
matt
remember the tranny temp will turn the fan on too!
matt
you cant go by the dummy gauge on the dash
matt
the heater issue could be a air pocket in the cooling system or a vacume leak or a water pump issue. the water pumps tend to slip on the shaft.there only pressed on
1 - 7 of 7 Posts
