1 - 8 of 8 Posts
2003 6.0 throwing codes for cam sensor and crank sensor truck seams to be in limp mode. No more than 1/3 throtle or it acts like its hitting a rev limiter replaced can sensor and still throws code spent all day at the shop and can't figure it out. Even put in a new pcm my friend thinks its a main harness but that's not cheep any ideas. Need help asap
"resident smarty pants"
Any hard starts? Check FICM voltage
Starts fine and I think the computer the guy At the shop used tested the voltage but I could test myself what is the proper voltage.
Well ford can't figure it out either ware to go from here they said it cuts out at 15 pounds of boost any one else have any ideas
ok one more shop down new crank and cam sensors they said it ran fine for 5 min then back to the same problem. no one has had this happen
Fixing Broken Stuff
What are the code numbers you are getting? Have you checked fuel pressure? What type of scanner are you using? One bad injector can make this engine not drivable.
1 - 8 of 8 Posts
