Hi guys
Here is my problem The AC doesnt work it only blows out hot air but if you turn up the heat it gets hotter. The A/C clutch is not engaging either.
I have checked the fuse in the right corner third down from the top under the dash.
I see that their is a relay and a diode under the hood. Do these go bad? How can you test if they are good or bad?
I need help quick because I am in Sacramento and the return trip is going to be hotter then hell:lame:
Thanks,
Andrew
Thanks,
Andrew
