1 - 10 of 10 Posts
Hi All - My Fuel Line leaks at the joint on the Banjo fitting. Ford has discontinued the Part - #F6TZ 9A 564AA. The IH # is 1825799C91 and IH says they do not have it and it is a "Ford Only" part.
The fuel line type is the kind that the Drivers Side goes into two 45�º brass fittings attached to the head.
Anybody have one for sale?
Thanks.
BIG_RED
i recently did a e fuel system. send a picture of the fitting and if i have it ill just send it to you
Hey Stever88,what exactly are you looking for? Is it the fuel line coming of the fuel pump? Is it out of a van? I might just have that. Just took some stuff of a 97 .
Homesteader - PMs Sent & Received.
Here are photos of the Banjo and Fuel Lines - if the photo's get posted, Thanks to Tank for his Sticky!
Problem solved, got it re-welded. Thanks for Replys.
1 - 10 of 10 Posts
