1 - 20 of 37 Posts
Big dumb redneck
Here are the bumpers I've been building over the past month. Finally got them installed a couple days ago. Sort of proud of myself. Started out as a project just to see if I could do it. Used nothing more than a welder, plasma cutter, and a grinder. They aren't perfect by any means, but I think they turned out pretty good.
nice work..
A Ghost these days...
Nice job. I like the design.
those are real nice, get a patent and make some money. i would buy them at a reasonable cost.
Nonsense specailist
Very nice. How did you get the edges so clean? Did you use bondo or something?
Those are nice. How long did it take you to make them?
Big dumb redneck
Discussion Starter #14
Thanks guys. They really weren't that hard to make. We process steel sheet here, so I just had them shear the pieces to the width I needed, then cut them to length with the plasma. Get your angles right, tack it all together, then weld her up.
For the seams.... I just welded inside and outside, then used a 80 grit flap wheel to grind it down smooth, then switch to 120 grit to really blend and smooth it all out. There were a few pin holes scattered around some of the welds that I just filled with bondo.
I think it took me roughly 8-10 hours to fab each bumper, then about half that in prep. Paint too me forever. I'm not a painter, never claimed to be. I think I painted and stripped them 3 times before I got it right. Used farm and implement enamel. Wanted something a little thicker and harder since they were bumpers.
OBS junkie
I took care of your other thread since you didn't need it.
BTW that front bumper is sweet! How thick is the steel & about how much would you guess it weighs?
Big dumb redneck
Discussion Starter #16
Thanks man!
I used 3/16" plate for both front and rear. I know most fronts that you can buy are out of 1/4", but I wasn't going to add tow hooks or a receiver or anything, so went with 3/16" to cut down on the weight. If I had to guess, i'd say it weighs about 150lbs maybe. It's not that heavy at all. I was able to pick it up and carry it around by myself.
those are sweet i say start producing them things and make some $$.
Big dumb redneck
Discussion Starter #18
I've had a couple different people want me to make them a set, but I made them here at my current job in my spare time. Thing about that is that I'm about to lose this job in about a month. I don't have the resources or the material to do this at home. I can get the material else where I'm sure, but I just don't have the space.... small house/lot. I'd have to do it in the garage, and my wife is already fussy about all the crap I have in there now! All of the steel I got from here for free! I have a welder at home, but no plasma/torch to do the cutting needed.
sell the design, you dont need any space to do that. all you need is a mail box too collect the checks. they would sell, and i would buy a pair.
Big dumb redneck
Discussion Starter #20
It's not really "my" design. I just copied one of BuckStop's designs. Was browsing around different companies looking for ideas and I liked their design better than the others (FabFours, Road Armor, etc).
1 - 20 of 37 Posts
