141 - 160 of 189 Posts
don't play well w others
Discussion Starter · #141 ·
The guy on the eastern shore finally got back to me on both rears. Only took him 6 months. I said I now only needed the front rear and 4 roller wheels. He started hem hawwing around again.
I found a rear on facebook not too far away with everything. Had 3.73 gears. As soon as I left the house it started raining. quit while we loaded it, and started again on the way home.
I learned from the trip to Tom's to take the toolbox out this time. riding down the interstate with the tailgate held shut with a ratchet strap wasn't one of the brightest things I've done in a while.
203549
putting it under the frame was a piece of cake
203550
203551
203552
203553
203554
Brackets off the 89 frame for shock mounts, loose ends being tied up
203555
203556
203557
  • Like
Reactions: Jax
Premium Member
It's about time you started working on this again!
  • Like
Reactions: Jax
Discussion Starter · #143 ·
Truck is still in " mothballs". Weather here has been obnoxious Frame is tarped up
I plan on starting on it in the next few weeks. Figured I better catch up on the thread first
Discussion Starter · #144 ·
I eventually intend to put a red head box in this truck like I did my Eddie Bauer truck, I'm pleased with that set up, but for now the stock box was replaced not too long before the truck was taken off the road, so it will be fine to build with. I used a rough country 4" drop pitman arm to tie the superduty steering links.
203571
next, I replaced the superduty hubs with warn hubs
203572
wiring harness and fuel system for the 89 truck is next. didn't really want to use the fdm for those years, and the 2 pump system, but that's the pcm I have so that's what went in. could be subject to change later
203573
203574
203580
Next was the sway bars. There are conversion setups for superduty to obs frame, but the 4 links and adapters cost more than I had in the rears, so I decided to build my own. 1st is a image of "theirs"
rest are mine I also used drilled and slotted rotors, and powder coated calipers.
203576
203577
203578
203579
  • Like
Reactions: heavydoc
Discussion Starter · #145 ·
Gas tanks were next. I had just replaced the front tank and low pressure pump, so a good clean up and back it went.
The back tank had been replaced before, but was needed again, so I decided to go with a Bronco tank from the same era.
The f series tank was 19 gallon, Bronco 38 gallon, so not a bad choice for a road truck or one pulling a trailer.
I never realized the bronco frame was narrower, and the crossmembers were closer, so I had to make my own upper and lower straps. Tom said the ratchet strap was fine, but I thought a upgrade was necessary
203581
203582
The blocks for the rear finally showed up, so I put them in. Much happier, not worried about them twisting out now. Like I stated before, these are for the F 450.
Next was to
203583
Next was to figure the brake lines. I had put stainless lines on the 89 a few years back, and they were still pristine, so I wanted to incorporate them
Down the frame was fine, but to the back rear had to change, accross the rear, and to the calipers. not to bad of a problem. front line was similar to the 89, but the way they hook to the master was different than the obs.
I decided to go with the obs set up, and had the lines made up
203584
203585
203586
203587
  • Like
Reactions: heavydoc
Discussion Starter · #146 ·
Gear oil change and covers next
203589
203590
203591
203592
Missed a step, I had to get some wheels and tires to make it a roller. Tom has a set, but a trip back to Jersey during the pandemic was out of the question. So I hit Facebook again and found a set of excursion wheels with half way decent tires.
They have the wrong off set, but do what I need for now
203593
203594
  • Like
Reactions: heavydoc
Discussion Starter · #147 ·
rear brakes were an issue, as the backing plates had rusted, and the parking brake pads had seperated and spun under the back set.
Probably a good thing, as one seal was pushed in improperly by the previous owner, and it had crushed the wheel bearings.
Th parking brakes were not fun putting on with the hub off, I can't imagine how much fun it would be with it on......
203595
203596
203597
203598
203599
another shot of the sway bar link on the back axle
203601
So that is about where we stand for winter on the frame
203602
203603
  • Like
Reactions: heavydoc
Discussion Starter · #148 ·
So the plan is to keep the 4.9 in the truck. I got 500,000 miles out of it with only very minor repairs over the years. I understand I have to upgrade and modernize some things, but that's not an issue. Most everything is still available over the counter for this motor, and there are still some companies doing aftermarket, although as time progress those have become fewer, being the last year for this motor was 96
203604
203605
203606
203607
203608
203610
203611
203612
203613
  • Like
Reactions: heavydoc
Discussion Starter · #149 ·
Rocker arms are 1.6 from a 85 5.0ho mustang motor. stock 4.9 in 89 were 1,5
Pushrods are chrome moly, and do not require guides
203614
203615
203617
The plenum, intake and exhaust are for a 96. That is the last year for the 4.9, but the best year for air flow.
This system would usually be a MAF system, but I will still be running it as a MAP system
  • Like
Reactions: heavydoc
Hey, Charlie, is that parking brake on both sides, or just the left?
  • Like
Reactions: tjctransport
Premium Member
well, he does lean very far to the left. she who must be obeyed is the one that leans to the right. :p
  • Like
Reactions: Jax
Discussion Starter · #154 ·
Brake is both sides
That rear belonged to Tom. So the one on the left was plumb azz worn out.
Too dam much weight on the non driver behind the steering wheel side
Premium Member
do you know how to tell the difference between a roller cam distributor gear and a stock cam gear? i have two distributors in the shop. one roller and one stock cam, but do not remember which one is which.
i would rather not find out the hard way and ruin a new cam and distributor gear.
Discussion Starter · #156 ·
The cam gears look the same, the one for flat tappet looks darker. Rollers are lighter metal
The cast iron gear will work on the roller, but will wear the cam.
The other gear will break on a flat tappet cam
Premium Member
lighter as in weight, or color?
Discussion Starter · #158 ·
Cast is darker. Later today when I get back to the shop I'll take a picture of the 2 distributer and the difference
Discussion Starter · #159 ·
Roller then flat tappet
Then roller on left
Premium Member
ok, thanks.
i have the two sitting on top of the engine, and both have points in them.
the roller is new, the non roller is only about 5 months old and is a clean as new.
i am using it the E303 cam and need the roller gear distributor
i also have to get a FE oil pump drive rod to run the Melling high volume pump because the points distributor is smaller than the EFI distributor.
