1 - 6 of 6 Posts
Pretty sure my FSU is malfunctioning. When filled above a quarter tank my gauge becomes erratic, jumps to three quarters, drops near E, etc, and eventually finds its way back to the proper reading.
My understanding is the most common cause is sulfur deposits having accumulated on the potentiometer (aka variable resistor). My plan is to attempt cleaning the device rather than immediately replace because of the crazy cost of such a simple device. Ford OEM is ~$370, and aftermarket (Delphi) looks to be ~$260. If cleaning fails, or works then fails shortly afterward, then I suppose I'll have to replace. In that case, I would probably just go aftermarket since they both have the same design prone to failure anyway (potentiometer spends its life stupidly soaking in diesel).
So then, how do we clean it? I did a small amount of research to find which easily available chemical solvents work best on sulfur. Sulfur in case you aren't aware isn't prone to dissolve in much of anything. First thought was vinegar (which works miraculously on most things) aka dilute acetic acid, but reportedly has very minor effect on sulfur. Other options are brake cleaner which is methyl acetate ("nail polish remover") w/ some hydrocarbons mixed-in, MAF sensor cleaner (n-Hexane), and acetone. Apparently n-Hexane and acetone can both dissolve sulfur. Solubility of sulfur increases w/ temperature. My idea is to soak the potentiometer in a warmed bath of acetone. Not sure about fumes, etc, but I will keep this far away from people while it soaks.
As for design improvement of the FSU, the potentiometer itself really should be isolated from the diesel fuel in some kind of sealed sleeve. The "wiper" design doesn't make that possible far as I can see. I really wish there were versions of the Metrum Rod FSU (sorry, my acct isn't old enough to post links yet) invented by "Leroy Diesel" designed for the various Ford Super Duty tanks... so far his only model is designed to be plug-and-play for some Chevy vehicles.
Actually, Chevron Techron fuel system cleaner contains Benzene and Xylene (among other things), both pretty strong against sulfur... so going that route instead.
I should mention again that I plan to remove the FSU and soak it, *not* pour the chemicals in my fuel tank. I don't think Techron cleaner is intended for diesels.
"resident smarty pants"
https://www.walmart.com/ip/Techron-Diesel/550482850?wmlspartner=wlpa&selectedSellerId=0&adid=22222222227128925733&wl0=&wl1=g&wl2=c&wl3=236871763133&wl4=pla-453881606837&wl5=9028155&wl6=&wl7=&wl8=&wl9=pla&wl10=8175035&wl11=online&wl12=550482850&wl13=&veh=sem&gclid=EAIaIQobChMIgITpjJn74QIV3rfACh0ZLAx7EAYYASABEgIzJ_D_BwE
[ame]https://www.amazon.com/Techron-Concentrate-Diesel-System-Cleaner/dp/B074JMSM96/ref=sr_1_1?gclid=EAIaIQobChMIgITpjJn74QIV3rfACh0ZLAx7EAAYAyAAEgI-IPD_BwE&hvadid=282532696549&hvdev=c&hvlocphy=9028155&hvnetw=g&hvpos=1t3&hvqmt=e&hvrand=6893398591167922456&hvtargid=kwd-315259006508&hydadcr=7467_9322228&keywords=techron+diesel&qid=1556743748&s=gateway&sr=8-1[/ame]
Thing is, Techron Diesel to my knowledge makes no explicit mention of dissolving sulfur deposits. Carbon, etc, yes. Of the list of solvents for sulfur I've reviewed, the chemical constituents on Techron Diesel's MSDS aren't among them. On the other hand, the Techron gasoline version *does* advertise to dissolve sulfur and its MSDS lines up with that claim.
I can try both. In each case I'll soak the removed sending unit in Techron concentrate. Will try diesel version first.
Just gotta get the damn thing out.
1 - 6 of 6 Posts
