1 - 20 of 27 Posts
Way To Many Projects
The long and short of the story is I got my truck 4-04 and sold to my brother in 9-08 to get my 08 SD (Dumest thing I've ever done). I got it back in 10-10 and have been working on since when I've have had time.
Well I've Been working on my truck to get it back up to useable conditon It needs a lot of TLC (Time, Labor, and Cash). I started by changing the trans, flex plate, new batt, driver door hinges, and brake line. I've driven a little now still got a lot of work to do. Short list
New windsheild find leak
Find oil leak (oil coller or turbo o rings or so I've read)
3" RSK and 2" front leaf springs, Lift rear 5" and 40"
Change front U-joints
SD seats or recover mine
Maybe change my motor with the one I have or chang over the stage 1's
And I'll add more More as I go I'm sure
Here's some pic
the truck
Inside
Trany out and flex plate
A few at home
And the parts truck that gave It's life for this truck RIP
I'll add more as I go
Thanks For looking JJ
Well I think I have a bad master cylnder on it. It's stays soft and dosen't come back up.
Well I fixed my Power steering pump pulley last night my brother pressed it on to far when he replaced the pump.
Thanks I think??????????
No offense but i wouldnt go over 35" tires and keep the truck usable...after all it's a nice crewab f350
None taking. It is a nice crew cab but it's my extra truck I've got an 08 SD for the heavy work. This truck did it's work befor that so now time to play.
OBS junkie
Nice, I know how much work goes into fixing up OBS CCLBs. :doh:
What happened to your flex plate? Mine looked a lot like it when I bought it.
My Brother changed the starter and left the top bolt lose and never fixed it.
Put the OBS to work tonight I was just moving trailers around
Is there anyway you would sell the tires and rims off that parts truck?
Not right now. and wich rims Stock ford ones or the aftermarket ones?
Either I just need some 16's in decent shape
Discussion Starter #16
Ok thanks I'll check it out .
Discussion Starter #17
Sorry didn't see your post I have the 16 alum ones but I holding on to them right now there was a guy on the org that had steel ones with three hub caps he wanted to sell.
Here an old pic from a cell phone i just found, not sure how good it will be, from when i broke the rear end and we pulled it up on my buddys trailer (at the time now mine) after we unloaded the two derby cars that I was pulling when it happend.
Discussion Starter #18
Well I had the OBS out mon driving it around Stoped and put fuel in the rear tank and 1/2 went on the ground. So it looks like a new rear tank. Then the front brakes started to grind so that the next project but wile I there I'm going to change the front U joint that are very very very bad so that way I'll put the front drive shaft back in. Well it never ends.
Yeah its always something. I think I either blew a head gasket or cracked a head this morning.
Discussion Starter #20
1 - 20 of 27 Posts
