1 - 6 of 6 Posts
my '97 has had a musty smell lately, where is the condensate drain and do they get plugged on obs's easily? I'm going check the carpet to see if right front is wet or elsewhere.
may have a mud dobber nest in it it is right below the heater bos if you peel back the insulation ( sfoil) you should see it on the fire wall.
thanks, I'll look today after work
oil burner
what kind of ladies have been in your passenger seat lately?:pointlaugh: just kiddin.
Terminator Nation
Sometimes the A/C ductwork gets moldy. I spray a big aerosol can of Lysol into the air intake for the A/C with the A/C running and fan on high. Outside of cab at base of windshield on passenger side into the grate. That generally does it.
sounds like a good idea, I'm not a lysol fan, but I have a produuct similar that I will use
1 - 6 of 6 Posts
