1 - 10 of 10 Posts
STILL LEARNING
Does anyone make a Muffler delete pipe?
On my 99 F550 the exhaust is all in good shape EXCEPT the muffler. It appears to be 3.5" but the problem is that the exhaust enters the bottom of the muffler and exits out the top.
No one around here bends anything over 3"
Try Auto-Jet Muffler on your search engine. It should bring up mandrelbenttubing-fabrication.com or something like that. They are located in Des Moines, IA. That is where I got my pipe.
STILL LEARNING
Thanks, I just emailed them. Did you have to bring them your truck to have them make it? or did they have one?
COMPUTER BLUE
you could also look @ doing a cheaper cat back sorta deal or downpipe back (they arent as much as you would think ). from diamond eye or someone like that. I know ken over @ kt performance.net has some really good prices
STILL LEARNING
I am not looking to spend over $75
My guess is it isn't your everyday run of the mill item, mostly because they are really only offered in an "offroad" aftermarket exhaust..
Premium Member
Brad,
I can get one....
i just took some 3.5'' straight pipe and cut the ends at angles to meet up were i needed it too. wasnt show worthy but worked perfectly. i welded it up as well no clamps
STILL LEARNING
Discussion Starter #9
mine has at least a 6" offset, so there is no way that would work for me
STILL LEARNING
Just put the Auto-Jet pipe on yesterday. Had to trim about 8" off of it but fit perfect. And It came with stainless band clamps. $90 shipped to my door
1 - 10 of 10 Posts
