1 - 19 of 19 Posts
drining my truck the past couple of days and out of no where it skipps a beat and blows a large amount of white smoke out the exhaust but then run normal for alittle till i gota give it more throttle then do it again and again and then sometimes it doesnt do it. wtf is going on? cam sensor? oil pump? anybody seen this? any help would be greatful.
oil, oil filter and fuel filter changed recently :confused:
Try the CPS and see if that fixes it. If it doesn't you now have a spare for the glovebox (always good to have). Cheers!
Cam Position Sensor, located at about the 11 o'clock position to crank pulley (has what looks like a timing pointer on it). Held in by a single 10mm bolt. With the white smoke that may not be it, but cheap enough to try. Cheers!
yeah cuse right now im stumped ive never heard of this kind of problem, but the cam sencor was the first thing i was gonna try seeings ford has a recall on them every year for my truck
DAMN THATS HOT!
Check all the relays under the hood too. Just try switching them all around and see what happens. My truck did this for a while and it was one of those relays. I replaced them all and never had a problem again. Actrually feels like it runs better since I did that.
Cantankerous Old Redneck
If you have a scanner check for codes....if you have a CPS sensor code, it could be the sensor, or the pigtail that plugs into the sensor. I had to change mine, and it can raise all kindsahell until you do.....get it from International...do a search for the part number....
sometimes yes, sometimes no....
does it sound almost like a kinda backfire, and then blows out white smoke ? if so, throw some Rev-X in it and drive it a while.....could very well be an injector sticking....
Im thinking injectors...hey man I have AE up here at my house if you wanna hook it up to the scan tool to see whats going on I believe Im like 2 minutes from you. Im on orphanage road.
Discussion Starter #14
yeah i know whod you are ive seen the truck on fb look me up i know your gf names ross thank ya
and yeah its like it back fires but doesnt keep it up just when giving it 50% or more in throttle i use diesel kleen which is suppost to prevent that but hell everyones products say that know a days
1 - 19 of 19 Posts
