1 - 8 of 8 Posts
ok guys so i have replaced every o ring, crush washer ect on my fuel system on the top of my block and the dang thing still leaks!!! what conversion can i do to eliminate the fuel bowl housing ect so i dont get any more leaks?:mad: i apreciate the info. and links, and prices if you guys can hook me up. thanks
Village Idiot
it may be cracked...(the bowl itself)
the usual fix is the 2 orings that are on the drain....
but to answer your q directly ...itp sells a fb delete kit.
Village Idiot
there is also a fuel bowl in the classified..just swap them out.
but i'd change the fuel line orings while your there
NEWBIE to PSN
Sissy,
Did you check the fuel supply line to passenger side head? About half way back it is held in place by a p-clamp. That has been the point of a few fuel leaks. I removed the clamp and placed a small piece of slit rubber fuel line over the hard line to protect it. Then just reformed the p-clamp around it and re-attached the nut.
Also on E99s the line that supplies the driver side head can rub on the IPR nut and wear a hole through causing a leak. Later models had a slightly different bend at that point and didn't rub.
Sissy,
hmm i will look for that this weekend thanks for the heads up man.
1 - 8 of 8 Posts
