1 - 5 of 5 Posts
Has anyone went from just power mirrors to having heat signal and power? I have a 2001 with the little mirrors but want everything.
Sent from my SCH-I535 using AutoGuide.Com Free App
Ok cool so all i will have to do is splice into my turn signal wire and running lights? Then just have the heat on an aux. switch?
That is correct.
I pulled the front turn signals off of the truck and got my power for the mirror signals there. Easy access and a straight shot back to each door. Soldered the connections and sealed them back up with heat shrink tubing and ran the wires through a small loom.
There was a wire under the dash on my brake control circuit that wasn't used for anything so I used that for the power for the marker lights.
I added a circuit that is operated by a relay and controlled with the ignition switch for power for the mirror heat and a few other options. Each branch of that main circuit is fused and controlled with a Carling switch.
1 - 5 of 5 Posts
