1 - 5 of 5 Posts
I'm in the process of upgrading the mirrors on my '01 to the '05 style heated with marker/signal lights. I've already modified my connectors and run my wires, I can handle the heater and marker light hookup but I'm wondering where to find my power source for the signal wires? The truck has the towing prep option if that helps. Thanks!
You need to tap into the wires from the turn signal switch. should be able to trace them down to the bottom of the steering column.
Thanks guys, I think I found the plug that comes down from the switch. I kind of anal about cutting in to the factory harness for some reason. I disassemble the plug connection and solder a tap wire to the desired connector and reassemble the plug. Crummy weather and working outside has made this a bit of a drawn out affair
Bobs 7.3
Thats a good,solid way of doing the tap.
1 - 5 of 5 Posts
