1 - 16 of 16 Posts
I thought up this wild idea driving home tonight. I know that tough country's 2.5" leveling kit rides really rough. I was thinking what if I used the drop brackets and got some mini packs for a 99-04 from Icon? This would keep the ride the same if improve it because I wouldn't nail the bump stops all the time. What do you think? I'm not doing the D60 swap fyi.
The mini packs for MAXX LIFt are good and cheap IMO
OBS junkie
You will need drop brackets for your TTB & will have to get it realigned. For the money, start looking around for a deal on a 60.
Yeah I know I can get the drop brackets separately. I'm just thinking it will do the same as the tough country kit but won't make the ride any worse.
OBS junkie
You have a TTB, there is no way you can get away from a rough ride.
I wouldn't spend a dime on a D50..save up for a D60
Discussion Starter #9
I understand what you guys are saying about the ride and the TTB in general. Would this work is my main question. I know it's not the best way of doing things but I'm not about to spend $2k on a 60 and RSK. My front end has about 20k on all new parts so I'm not replacing stuff if there is nothing wrong with it. I just want a little lift so my tires stop rubbing the bumper.
Not to hi jack the thread but Im in the process of doing a d60 swap right now. im using the 350 springs and everythring. How much nicer does a d60 ride over a stock ttb? And also how much will it lift the front end? Thanks.
OBS junkie
With the 350 springs it will be night & day & should lift the front end around 2".
Will ride better but nothing like a RS kit and SD springs and correctly valved Bilsteins.
Cary
1 - 16 of 16 Posts
