1 - 6 of 6 Posts
Hood Rich
I think my turbo is starting to go. I want to go to a Precision since they are only a few minutes away from me. Question is what do I want to do with the wastegate. Do I want it to be set at a certain psi or what? Truck is damn near stock, just Beans tunes. I want to keep it relatively stock and safe though. I dont plan on injectors since this is a PMR motor.
Oooo, White Lightning !
Then just leave it stock. Maybe a little tighter.
Im not sure that it will do much anyways.
Since the truck is stock its not going to build much boost, so if I were in your shoes I would just leave the waste gate in the factory setting.
Diesel boy I always drool when I see your sig.. Have you ever run that monster down a strip? Sorry to high jack this thread I'm just curious as hell
Busy Busy
Put a nut on it so you can adjust it once installed. Then ay around with boost pressures.
Thanks. Not yet, Ive done a few runs down some back roads tuning the PCS :pullover:
Cant wait for the summer. Let er eat.
1 - 6 of 6 Posts
