Yep, I have egt on both sides - never know. From right to left they generally run within 40 degrees of one another. Hope it's not too bad. I'll be following you down tomorrow just incase.Stock uppies are just regular metal,exhaust piping.
My R/S pipe started to melt at the manifold,hopefully it is from the track and not when im on the highway.I think im going to start being a gauge whore and hook up another pyro on the R/S manifold plus acouple other gauges.
Isn't Joe the resident guage whore???:swordfight:Stock uppies are just regular metal,exhaust piping.
I think I got him beat.Isn't Joe the resident guage whore???:swordfight:
Everybody is saying they are melting but what you describe sounds like they are expanding due to the heat and they are wrinkling/collapsing (like corrugated cardboard). I heard it suggested that this might be due to doughnuts that do not allow the pipes to slip, ie. they are fixed on both ends and when HOT can only expand and collapse as you have described. Is it possible that in an attempt to eliminate leaks at the doughnuts, we have created this problem with the up pipes? No flame intended. Just a crazy hypothesis.Mine melted and I was running in the 1750-1800 degree range for bursts of no longer than 40 seconds.
They both got all wrinkly and warped near the manifold on each side. Pretty much just wadded them up at the bottoms. Also cracked the passenger's side manifold between 3 and 5 as well as sheared the rearmost bolt on the driver's side.
Sounds reasonable to me. I just thought they were stainless. I know we have run mine at over 1800 for at least ten minutes at the time, and no problems?? Not saying I'd recomend it, but ......
But they also were leakers. On a good downhill run it would cool enough to really leak bad when you get back on the gas, till they got some heat in them. So, if they're regular mild stell, then how do they stand the heat as good as they do? A turbo with an inconel wheel is weaker than an uppipe made of mild steel? Always hearing of burned up turbos, and not much talk of uppipe failure. You SURE they are reg. steel? I was told the stock exhaust was plain old muffler pipe....NOT! We tried to torch out the stock downpipe , and it is def. some grade of stainless, or at least coated. It doesnt cut, it blows out.
So, are they coated or what?
Pretty good so far. I dont really know for how long it was like that. I just know that after I got gauges, it was scary climbing some of those hills at wot for ten minutes at a time. I was to dumb to back out of it. I have seen the egt gauge pegged out for ten minutes solid. Bigger than stock injectors, van turbo, stock exhaust. I think the problem was the exhaust, cause after putting on the 4" it never went above 1,200. If I downshifted the egt went higher.How does your engine, turbo, etc endure that?
With that history, it will be very interesting to look at the ring lands and fuel bowl in the pistons when they come out.Pretty good so far. I dont really know for how long it was like that. I just know that after I got gauges, it was scary climbing some of those hills at wot for ten minutes at a time. I was to dumb to back out of it. I have seen the egt gauge pegged out for ten minutes solid. Bigger than stock injectors, van turbo, stock exhaust. I think the problem was the exhaust, cause after putting on the 4" it never went above 1,200. If I downshifted the egt went higher.
Everyone kept telling me that they would go down if I dropped out of OD, but they only went up. So, I towed at 2,100-2,300 rpm in OD. Climbed hills very well, just had high egt. Again, I dont recommend ANYONE doing this.
I may regret it in the future as the wear and tear shows up, but for now all is well!:ford:
Maybe my egt gauge is off by five or six hundred degrees?
