1 - 4 of 4 Posts
what do I have to do to get the small rubber hose off the EGR cooler on my truck so I can get it and the intake manifold off my truck? Is there a trick? I would appreciate any help. Thanks...
Administrator
EGR Cooler: Removal & Installation
Before removing the EGR cooler, you must first drain the coolant from the cooling system.
To disconnect the hose that supplies coolant to the EGR cooler, rotate is and pull until the tabs release.
Both the inlet and outlet for exhaust gasses are sealed with metal gaskets.
The coolant connections are sealed with o-rings.
1 - 4 of 4 Posts
