1 - 20 of 38 Posts
Never Fry Bacon NAKED!
What is the formula to figure the correct MPG if a speedometer is reading 5 MPH faster than the actual speed of a vehicle?
Thanks.
Stewart
An Ancient view on life
Miles driven=M Fuel used=F
M / F = MPG
Now if at a true 70 mph but showing 75, divide the real mph (70) by shown mph (75). 70/75= .933333333
Then multiply MPH by .9333333 or what ever number you have and wala.
Example
600 miles
11 gallons
600/11=54.54
75 speedometer reading 70 real MPH
70/75=9.33
54.54/.933=50.909 real mpg
Now all that said, you really need to check the miles driven (actual) versus what your odometer is showing. I do that by checking with the freeway mile markers versus that my odometer shows. Not perfect by close.
Typical mpg of my 2003 VW Jetta.
JonFord :ford:
Also you need to know that after 2 years of College, the Dean wouldn't let me go back and I wouldn' go back.
:whs: looks right.
M / F = MPG
Example
600 miles
11 gallons
600/11=54.54
70/75=9.33
You have a couple mistakes, but I get what your saying.
I'm sure you meant for me to multiply Miles Per Gallon (MPG), not Miles Per Hour (MPH) by .933.
And in your example, I know you meant to post your example as:
54.54 x .933, not 54.54/.933, right?
Just curious though, when I multiply 54.54 by .933, I get 50.88582
Why?
I knew my true MPG would be less than the 15.54 MPG I got with my last tank, I just didn't know how to factor in the 5 MPH difference, that's why I asked for the formula so I could get my actual MPG.
I don't understand what your last quoted paragraph has to do with the formula.
Stewart
ARMY bound
If it's reading different because of tires and such, it's a fraction of speed rather than a solid 5mph. Just something to keep in mind.
King Dingaling
you can get close,...but you still won't be accurate.
when your mph is off,...it's not a standard "5 mph"
if you are 5mph off a 70,..then you're about 7mph at 80mph...etc etc etc
Why would that be? If the difference is from the size of the tire, the size doesn't change with speed, it's constant. Shouldn't the factoring difference be constant also?
Stewart
Mine is 5 MPH off at any speed.
Stewart
green member
Stewart
LOL ......rethink what the others have posted and what I quoted.
If you are right your speedo reads 5mph when in Park, if they are right your speedo reads 0 when parked.;)
green member
He's forgetting something......tire size doesn't change but the number of times they go around and around in an hour does.:doh:
LOL! I guess.
I'll be more specific. My speedo shows 5 MPH faster at 55, 60, 65, and 70 per a calibrated radar unit.
Stewart
Discussion Starter #14
Ah, ok...that's the variable with regards to the tire size. That I understand, and is why I questioned it. It didn't just make sense immediately.
Now, I never said the cause was my tires guys. I have no clue what it is. I just got the truck and I'm checking things out as they become apparent to me.
Stewart
Stimulated
Stewart
There's only one way this can happen. If you take off your needle and put it back on wrong. That happened to me on my Crown Vic. If you have bigger tires, it will be off by a percentage. Here's how:
31" tire- 31x3.142 = 97.402" circumference
there's 5280 ft in a mile, or 63,360 inches
divide 63,360 by 97.402
that gives you 650.499 revolutions per mile
35" tire = 109.970" circumference = 576.157 rev/mile
650.499/576.157 = 1.129 or 112.9% of the original indicated speed
you are now off by 12.9%, giving you an indicated speed of 79.03mph when your actual speed is 70mph
The same coefficiant, 1.129, would apply to distances as well. Take your indicated distance, multiply by your number, and you have your true miles.
Discussion Starter #16
I tried telling him....LOLLOLLOLLOL
No, you didn't
"Telling me" implies explaining to me. I asked for an explanation and I get ridicule?
"I tried to tell him"
Please.
Keep your supposed "help" to yourself if you lack the intelligence to explain to someone on the forum a direct question on why something is.
Stewart
King Dingaling
Wow....all that came from you,....your actually a tard in person....:poke:;);)
Discussion Starter #18
Thank you Matt for EXPLANING to me why there is a variable factor if the problem is from the tires.
I have no clue why my speedo is off at present time.
I never said it was from my tires guys.
Stewart
King Dingaling
No, you didn't
Please.
Easy there tiger,....I WAS trying to help,...sorry if you took it any other way.
1 - 20 of 38 Posts
