1 - 3 of 3 Posts
young buck learning.
i blew the turbo boot off last night and i went out to fix it this morning but couldnt cause it blew the clamp clean in half. but anyway when i was pulling it in the garage i had the hood opened and noticed smoke coming from the engine bay, so i had a buddy rev the motor while i tried to see where it was coming from, its on the drivers side but i cant tell whether its the manifold or up pipe. the very last exhaust port has a little bit of black around it but it doesnt exatly come from there. should i replace the exhaust manifold gaskets? if the up pipe is leaking how do i stop it?
The Unseen Mod
Actually from the factory there are no exhaust manifold gaskets, you can get them afterwards, but look at your bellows on your ypipe n ypipe contections as well.
Also just check the bolts on the exhaust manifold's.
I had a leek that I was chasing for a few weeks and finally found the bolts were just loose.
1 - 3 of 3 Posts
