1 - 9 of 9 Posts
I'm installing auxiliary switches in my dash, where the 4x4 knob would be. What is the best way to cut through the dash so I can put the switches in? Any help would be appreciated!
Master BS'er
Drill a hole big enough to fit a small saw blade in it, then cut out the square. Or use a cutoff wheel but that's not easy to cut square with a wheel. Up to you.
multitool works great for plunge cuts into plastic
You can heat up a steak knife and push it through also, remove, heat, cut, remove heat cut until you have your square
  • Like
Reactions: jamiesaun
Administrator
Glad to see im not the only one with a steak knife in the tool box
my steak knife is one of my fav tools, when crushing trucks it is soooo handy to cut through hoses it gets used!!
Administrator
And dry wall in a pinch.
  • Like
Reactions: 410customs
1 - 9 of 9 Posts
