1 - 10 of 10 Posts
Busted Knuckles
Just wondering where I can get the brackets, bushings, and the end pieces that go into the bushings and screw into the ends of the bars?? Thanks for your help!!
wheres the fat chicks?
wandering about this as well
I've used Ballistic Fabrication in the past with good results.
A Ghost these days...
Busted Knuckles
Discussion Starter · #5 ·
Thats exactly what I'm looking to do! About how much did they cost you and what all parts did you have to get.
Only money I have in it is for the Heim Joints.
MXM-10 Midwest Control Chromoly 5/8" Rod End
5/8" -18 tpi Jam Nut
If I had it to do over, I would have probably gotten a 3/4" joint. These will be fine though im sure.
~ Solid 1 1/4" o.d. Round Bar = work
~ Drilling / Threading rod ends = work
~ 5/8" x 4" lg studs = work
~ Misc Brackets = cut out at work (lazer cutter)
I dont know if you can tell, but I did most of it for free at work....
I guess I have about $25 tied up in my traction bars.
Busted Knuckles
Discussion Starter · #7 ·
Hmm well I know a guy that has a welding shop and a bunch of machining equipment so i'm sure I could get him to drill and thread the round bar. Thanks for the info man it really helped me out!
*** has a kit out.
BRING DA AMBALAMPS
poly performance, dirtfab, barnes4wd, and ballistic fab all have the stuff you need.
1 - 10 of 10 Posts
