Since no easy lockers are available for the Dana 80 w/ 37 splines I'm getting ready to take the plunge on a real LSD. I'm thinking in theory here, and seeing if anyone agrees or if I'm crazy for even thinking it.. but if I replace the open diff with a LSD unit and the ring/pinion are the same and all caps/shims re-installed exactly as they came out, there shouldn't be any reason why I run into a major setback on setting backlash/pinion depth etc. right? I know Murphy's law, but if the LSD is the same dimensionally as the open carrier, nothing should change right?
Of course I'd set up the dial indicator when I'm done and torqued and check it, but if it's out then I'll have a lot more down time trying to locate shims etc. Shouldn't be out though right? All that would be new is the LSD carrier and new bearings pressed on with the same ring gear bolted onto it.
I'm looking at a Yukon YDGD80-4-37 most likely. Open to suggestions if anyone feels there is a better unit.
