1 - 4 of 4 Posts
Back in Black
Im looking to lower my 09 6.4 I already cut the front springs down and removed the block from the rear. but I want to go a little lower.
How low can I go and still fit 33's? and also is there a DIY way to do it? I looked for a kit and only found one and it was close to a grand but didnt look like it had new front springs or anything...
Thanks guys
I did 5.4 Super Duty springs in the front and no rear block in the back. It fit my 305/55/20 Toyo Open Country AT's just fine with 20x9 BMF Novakanes. That tire is pretty much a 33/12.50/20. I could have gone lower in the front and rear with those tires.
Back in Black
thats now mine sits now, but id like to go 1.5 lower
mine is pretty much like Jeff's in this pic same front coils . i pulled the block and the thick rear and overload springs just to see how low it would look . my tires are like 32.5" tall but still i think you could do it .Up front you might be able to cut a little more coil and trim your bump stops .
[/IMG]
1 - 4 of 4 Posts
