1 - 5 of 5 Posts
Hello I am new here to Powerstroke nation. I have an early 2004 f350 6.0 its 4x4. The truck idles at 500 rpm it only shuts off after i have been driving above 65 mph for 10-15 min or more then as i start to hit the break and get to a lower speed is when it shuts off. i just put a new turbo, intake manifold, icp sensor, and egr delete in it. I am completely lost as to why this is happening it does not leave a code and the mechanic said that my IPR is good. Any help would be appreciated.
Banned
What are you/the mechanic using to check codes? Do you have anything to datalog with?
its not showing any codes he thinks it might be the wiring harness. im not sure if he is datalogging anything or not but im sure he is
Banned
Keep an eye on the ICP voltage, actual, desired and IPR Duty Cycle.
Also, watch FICM voltages
1 - 5 of 5 Posts
