1 - 5 of 5 Posts
ok I have a early 2004 ( call it 2003) f250 and I got a scan gauge and am seeing some decent difference between eoc and ect like 20 degrees running around town. not noticing any leaking and no residue at degas bottle. I need to check my temps on a cold motor, to make sure not a sensor issue.
and on to the questions, I have been looking and finding conflicting or confusing info.
I would love to replace the oil cooler with the bpd set up/ money wont let it happen right now.
I read there is a new oem style oil cooler, what is up with this, is it better/ last longer?
what kind of life are people getting with oil cooler replacement/ im seeing 300-50000?
guessing I need to flush and replace thermostat.
dumping my money into a head gasket stud kit, with bpd egr cooler and associated pieces. maybe if I can get 50000 out of this cooler I can then afford the bpd set up.
I also see other cooler replacement systems, any ideas, seeing mixed reviews
any and all input appreciated
"Slap hands slap hands"
My understanding is that the new oil coolers are way better then the stock ones they put in our trucks 10-11 years ago. I have had mine for about 25,000 miles and it's still working like a champ I put the OEM one in not sure if it's the same one your referring to. 20 degree difference is a lot the most I see when towing my boat or ever is 12 which is rare my truck usually stays around 7-10 degree difference at most.
I was seeing differential temperatures of around 60 degrees. Yep, my oil cooler was 100% clogged.
I'm in the process of replacing it with an OEM piece right now (along with a lot of other stuff - studs, HPOP, etc.). As long as you do an extensive coolant flush (mine will be with Restore and then Restore Plus), add a coolant filter after, and use the correct coolant (silicate free Cat EC-1 approved) I believe the stock oil cooler won't have any problems. It only turns into a problem when it clogs with silicates and/or iron rust.
My truck is a September 2003 build as well.
1 - 5 of 5 Posts
