1 - 4 of 4 Posts
A friend of mine has an '02 7.3 with 109k miles on it, started getting hard to start, then now it will start but rocks horribly and is missing. I told him it sounded like it dropped an entire bank of cylinders due to a bad valve cover gasket/harness....
so he started the truck and unplugged the driver side harness, engine died immediately. Started it back up unplugged the passenger side harness and there was no change. So, he purchased a new Felpro gasket/harness, installed it and got no change??
What would kill the whole bank that is not the harness/gasket?
What should we look for?
Any hints or tips to try?
Thanks,
Justin
Haters Gonna Hate
Thanks,
Justin
id check for voltage at the pins on the harness side, make sure u are getting votage that far
one of two things,,,the harness on that side is toast, or his idm has went bad..i would do a stated above,,,check the voltage first
Well Hung Member
yea, make sure that the harness is actually getting power to it, i prolly woulda tried the same thing as far as replacing it first,...hm, maaaybe rodent damage on the harness going to it? happens waaay too often,
1 - 4 of 4 Posts
