1 - 6 of 6 Posts
I've lost power to the windows in my '01 F-350. I've got power at the breaker, the breaker shows continuity but I don't have power at the switch. It was working when I dropped it to a shop to have the oil pan replaced, they used the method of cutting the crossmember, didn't lift the cab. The last thing I did when I parked the truck there yesterday was raise the window up. Is there a likely spot I should look before crawling around under the dash trying to trace it?
I would start in the wire loom between the drivers door and the piller. most of the time the wires break from opening and closing the door.
do you have an aftermarket alarm that locks and unlocks the doors?
mine did this and it was the 2 relays that they wired in, one had come loose, took me forever to find it, tucked away under the kickpanel on my passenger door, but mine is an obs.
Do you have any other funny electrical things happening? A bad GEM can cause that
I haven't noticed anything else, do you know what might be effected? I can check it out. I was wondering if there was some module that might have been effected by the welding done to the truck. Where would I find this module? I can check power in and out on it.
Got back at it today and determined the power mirrors weren't working either and that I had no power to them. Went back to the owners manual and found the fuse listed for the mirrors, #4 which is 10 amps. The windows weren't listed as part of that circuit but I checked the fuse and lo and behold, it was blown. As I replaced the fuse, I heard a relay click under the dash and power to both the mirrors was restored. I'm glad it was that easy, it seems there's a relay for both accessories to be powered.Thanks for the help guys!
1 - 6 of 6 Posts
