1 - 4 of 4 Posts
Well I have the beacon already and just use the cigerete lighter plug in but would rather hard wire it in the truck with a switch. I don't have upfitter switches so where would be an easy place to get power from?
Media Mushroom Stamp
If you want to be able to control it with the truck completely off, tap into the large gauge yellow wire coming from the steering column. If you want to go with accessory power so it will shut off when the truck does, it'll be the red/black wire in the same harness as the yellow one.
Make sure the wires you grab are the 10ga ones coming off the ignition switch and not he airbag harness, and don't forget to fuse them
Check your local laws before hard wiring. Around here you are not allowed to hard wire one into a personal veh you have to be able to unplug
1 - 4 of 4 Posts
