OASIS RESULT: 1FTSW21RX8EA40665
USA: EN-US
16-DECEMBER-2011 / 06:50:36 / FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION: 2008 F-SERIES BODY STYLE: F-250 CREW CAB 4X4 ENGINE: 6.4L TC DIESEL V8
TRANSMISSION: TORQSHIFT AXLE CODE: 3L ENGINE CALIBRATION: 8F716A0A
PAINT COLOR: SILVER MET WATERBORNE PAINT CODE: Z3 RADIO: PREM AM/FM STRO/CD CHANGER/CLK
AXLE RATIO: 3.73 FINAL DRIVE RATIO WHEEL SIZE: 8 X 18" PREM CHROME STEEL WHL FRONT TIRE: LT 275/70R18E A/T OWL
GROSS VEHICLE WEIGHT: 10,000 LB. GVW
WARNING MESSAGES
VERIFY STATE REGISTRATION, VIN MAY BE ELIGIBLE FOR CALIFORNIA EMISSIONS WTY
ACCURATE REPAIR NOTIFICATIONS
ATTENTION TECHNICIANS AND SERVICE MANAGERS:
TO ENSURE OPTIMUM COOLING SYSTEM PERFORMANCE, REFER TO 09-08-05
FOR DTC P040D SEE 11-06-15
FOR RADIATOR COOLANT LEAKS SEE 11-12-04
GENERAL WARRANTY INFORMATION
New Vehicle Base Warranty
WARRANTY START DATE: 06-JULY-2007 BUILD DATE: 14-MARCH-2007 SALE MILEAGE: 00083
OUTSTANDING FIELD SERVICE ACTIONS
11B23 POWERTRAIN CONTROL MODULE RECALIBRATION
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
17-FEBRUARY-2011
DEALER: Folsom Lake Ford, Inc.
WARRANTY CLAIM NUMBER: 609667 ODOMETER: 033306M
PART NUMBER PART DESCRIPTION QUANTITY
LABOR OP
CONDITION CODE
CONDITION DESC
9C3Z 5H221B FLTR ASY ENG EXH PRT 001 5221A 42 DOES NOT OPERATE PROPERLY
7C3Z 5H247B FLTR ASY ENG EXH PRT 001 6005F
8C3Z 5J213D SNS ASY-ENG EXH TEMP 001 6005F1
000 6005F6
000 6005F47
000 6650AA
000 6005F11
000 6005F13
000 6005F45
000 6005PA
RAN THE ENGINE UP OPERATING TEMP TO GOVERENED SPEED AND VERIFIED BLACK SMOKE FROM THE EXHAUST. SHUT DOWN AND LET SIT CHECK THE OIL LEVEL SHORT STICK AND FOUND OIL IS AT THE CORRECT LEVEL. INSTA PART ARRIVED WHILE TRING TO REMOVE THE EGT FOUND TO BE FROZEN IN THE DPF. TRIED TO SOAK EGT SENSOR WITH PENITR ATING OIL STILL WOULD NOT COME OUT, TRIED HEAT ON THE EGT SENSOR STILL WOULD
Click Here for Full Warranty History
SYMPTOM CODE INFORMATION
992*** -
Maintenance/ Pre-Delivery > Maintenance
SPECIAL SERVICE MESSAGES
22074 2008-2010 F-SUPER DUTY, ECONOLINE PCM/TCM PROGRAMMING ERRORS DUE TO AFTERMARKET DEVICES CONNECTED TO THE HS CAN NETWORK.
SOME 2008-2010 F-SUPER DUTY AND ECONOLINE VEHICLES MAY EXPERIENCE DIFFICULTIES DURING PROGRAMMING OF THE PCM/TCM DUE TO AFTERMARKET ACCESSORIES TIED INTO THE HS CAN NETWORK. PLEASE REFER TO SECTION 418-00, INSPECTION AND VERIFICATION FOR INFORMATION ABOUT AFTERMARKET DEVICES. THE TYPICAL LOCATIONS FOR AFTERMARKET DEVICES ARE FOUND IN THE AREA OF THE DLC, THE DRIVERS SIDE FRAME RAIL NEAR THE TCM, OR ANYWHERE THE HS CAN NETWORK WIRING CAN BE ACCESSED. IF DIFFICULTIES ARE EXPERIENCED DURING PROGRAMMING, DISCONNECTING THE AFTERMARKET DEVICE MUST BE PERFORMED IN ORDER TO CONTINUE WITH PROGRAMMING. IF THE ERROR HAS LEFT THE MODULE UNRESPONSIVE TO PROGRAMMING, REFER TO THE MODULE PROGRAMMING AND REPROGRAMMING DOCUMENT FOUND ON PTS, UNDER THE SERVICE TIPS TAB, JOB AIDS SELECTION, TO ASSIST IN A BLANK MODULE CONDITION RECOVERY.
EFFECTIVE DATE: 10/20/2011
