1 - 16 of 16 Posts
· Registered
im looking at getting hid light for my truck and i was wondering if there is kits that are better than other or what not im looking at the one w 8000k hid kit here is the link 8000K HID Kit [8000K] is there better brands than other or no? also there is a wiring kit for the lights not turning on or something should i get that to ? HID Kit Wire Relay Harness [Harness]
thanks justin
· Registered
custom HID conversions, HID kits, LED, CCFL specialists - retrosolutions
They're by far the best company to deal with HID wise that I've come across. Todd can hook you up with everything you need at a good price.
The ones on that site are not bi-xenon, thus you only have HID's when your low beams are on and your high beams are a regular type. Not the best you can get.....On edit, those are some crappy packages, if they cannot provide the wiring that other systems do standard, I'd stay away from those guys.
· Registered
well i considered retro once i read the other persons post, so this are hid hi and lo beam? also whats there like a special price for psn members? just b/c what u said in your post just curious thanks
· Registered
The ones in the link you posted, from the pictures and reading the descriptions, they're lacking in quality. From what's listed, I'm assuming they don't provide a relay with their kit, thus it being listed separately. Also, they ones you linked are either low beam or high beam, not both.
Retro-solutions offers Bi-xenon kits that are both high and low beam. (Basically a moving bulb.) Either way, they're a superior choice.
I'd look into a 55w kit. They 35w kits from what I've delt with seem quite a bit dimmer.
I'm not sure on the PSN discount, it's posted in the Retro Solutions forum in the Vendors section....I think the code online is just PSN, or you can call them and say you're a member here.
· PSN Mega Miler
Another retro vote. Only way to go in my opinion. Love mine.
· Registered
Well if you're talking about buying from Retro Solutions, yes, if that is the correct bulb type for your truck.
On a side note, 4300k is closer to the sun, thus technically brighter. I have 5000k or 6000k and they're white and really bright. 8000k would be more blue and dimmer than the one's closer to 4300k.
· PSN Veteran
Another satisfied customer of Retro here, got thier 4300K kit and couldn't be happier.
· Registered
Discussion Starter · #12 ·
ok well i put the light in and my left head light does not not always turn on so i have to turn the lights off and then turn the on again and it will turn on any ideas? bad ground or?
· Registered
More than likely a ground issue. That's the only problems I've run into with mine. The "auto" on feature for the headlights can sometimes make one of them not come on but that has happened to me once in the few months I've had mine.
· Registered
Discussion Starter · #14 ·
ok i will clean area out a little more, then i will try if that dont work ill call retro. any other ideas connections are all tight. also where has everyone else mounted there balllast?
1 - 16 of 16 Posts
