1 - 6 of 6 Posts
Changed fluid in my rear diff today, used Redline 75-140...on the tag on the rear end it has S 406 H, and 31k30 3.73 ratio.....is there any way to tell from the tag if it is limited slip or open? Also, after driving it about 12 miles, and starting from a stop light on a slight hill (up) i got a clunk that could be felt?????? From the rear end area.......there are no leaks, filled the level till it seeped out the fill hole....???? any guesses...it did fine while driving..(the u-joints are ok...2002 F250 4x4....rsbhunter:postwhore2:
owner/president
Need the axle code in the drivers side door on the vehicle certification label.
Keep er shinny side up!
could be the slip yoke needs some grease.
Yes you can tell LS or open by the tag.
If it says 3 73 it is open
If it says 3L73 it is LS
didn't see the L, so i'll assume it is an open...the tag on the door is unreadable on the bottom, where i guess the axle code would be.....can a dealer tell by VIN code?....The slip joint grease sounds completely possible..will check tomorrow...thanks for the help....rsbhunter
dinnerbooter treasurer
You could jack the back wheels off the ground and spin one of them. If they other one spins the same direction you have limited slip if it spins the opposite direction you have an open differential.
1 - 6 of 6 Posts
