1 - 16 of 16 Posts
wheres the fat chicks?
i just got a build sheet on my truck and it says that my truck has a limited slip diff. in the rear.but recentley i was stuck on some ice and only one tire would spin.isnt the other tire suppose to kick in and start spinning too?or am i wrong to assume this.
owner/president
Whats the axle code on the sticker in the drivers door jam?
here is a pic of the sticker
owner/president
Its a LS,but thats the way Fords work:doh: unless you install a true locker.
owner/president
If you jack up the rear end and turn one wheel,the opposite wheel should turn in the same direction also.
i will try that tomorrow.the LS not working wouldnt affect the gears inside it would it
i tested it today and there isnt a limted slip in it
owner/president
Sorry to here it.I couldn't read the door jam sticker.
oh well
owner/president
You could always change out the internals or swap axles.
Put a trutrac in it. You won't be disappointed
the factory limited slips don't last forever. if there are more than 60K miles on the clutches then they should get changed. but personally i would just get the geared limited slip and be done with it.
mine doesnt work either:lame:. true track and gears when i have the money!;)
owner/president
I have one with 80,000 and 190,000 and i can still light-up both tires.
1 - 16 of 16 Posts
