1 - 4 of 4 Posts
I have a 02 X. The alternator was replaced 30k miles ago. My lights appear to pluse or dim consistently. It's all of my lights not just head lights, dash lights radio lights also. Could this be alt. on the way out or two small of an alternator? I don't have any big add ons that require extra power. I almost make me dizzy driving. Any ideas, advice?
Thanks
Mine had the same problem. First thing to do is pull your alternator off and take the batteries out and have them tested. Also check all your connections. Mine ended up being a loose connection on my feeder battery. The connections have to be tight and clean or you will not get the voltage you need.
tightening the loose connection took care of the flickering? I'll be on it in 20 min. thanks
yep it was just a loose connection. simple fix. thats how i know when the connection gets loose again they start flickering.
1 - 4 of 4 Posts
