1 - 3 of 3 Posts
The light on my drop down DVD will not go out. When I shut the door the dome lights go off but the lights on the DVD player stays on..:confused:
Always Learning
Did you just have it installed? Is it the factory one or aftermarket? If it is aftermarket....then the door trigger wire has been hooked up to 12 constant.
I figured it out. The ground wire for the aftermarket dvd player was connected to the dome light ground. So when I put the LED bulbs in the dome light it created some sort of problem, when I took out the LED bulb and put back the regular bulb it was fine.
1 - 3 of 3 Posts
