1 - 1 of 1 Posts
Kevin
Has n e body had a lifter go out on a obs with under 200000 miles on it with 180's and off the shelf tunes? No bent pushrods, no brock rocker arms, straight edge on the valves and and there all flush, its got to be lifters. It pops when you crank it out the exhaust and then goes away after about ten seconds. Smokes real bad then goes away with or without the chip and I done went threw all the injectors and there fine. Just want to know if im the first with this problem or if its happend before. :shrug:
1 - 1 of 1 Posts
